POV-Ray : Newsgroups : povray.newusers : how to make a blurry reflection? Server Time
9 Jun 2026 02:06:52 EDT (-0400)
  how to make a blurry reflection? (Message 1 to 9 of 9)
Subject: how to make a blurry reflection?
Date: 26 May 2026 13:30:00
Message: <web.6a15d851679d85a1172a7c81d49cbb40@news.povray.org>
Hello, I have a question: how to make a blurred reflection in Povray version
3.7?
Download 'rdt_20251015_1132498961558942031733869.jpg.png' (2912 KB)
Preview of image 'rdt_20251015_1132498961558942031733869.jpg.png'
Subject: Re: how to make a blurry reflection?
Date: 26 May 2026 17:30:00
Message: <web.6a16104ebb25f7d0e83955656e066e29@news.povray.org>
> 3.7?
The method I know of is here, under the heading: "Is blurred reflection possible
in POV-ray?"
https://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips#Topic_13
It works by averaging multiple almost-identical textures, each with a
different 'normal', to create the blur.
Date: 27 May 2026 02:50:00
Message: <web.6a169401bb25f7d017bac71e8ffb8ce3@news.povray.org>
> 3.7?
Use a very scaled down normal and keep the "hight" of it relative big. Use a
patter like granite or noise like
ingo
Date: 27 May 2026 07:07:46
Message: <6a16d082$1@news.povray.org>
> 3.7?
Work with versions 3.3+.
Two ways :
1) Micro-normals. Use some normal, like granite, scaled very small. Need
to use antialiasing to work.
2) Averaged normals. Apply many normals randomly displaced. Really slow
down the render. You must avoid inter reflections between surfaces with
blurred refection. Use no_image and no_reflection this way : One object
with the averaged normals and the no_reflection attribute. Don't show in
reflections.
A second identical object with micro-normals or just normal reflection
instead of the averaged normals, and the no_image attribute. Not visible
directly, but shows in reflections.
Micro-normals work best with some averaging. Normally, 5 to 10 instances
are OK.
Averaged normals usually demand 200+ instances.
With version 3.8 and radiosity, you can get blurred metallic reflection
using brilliance.
Need to add «brilliance on» in the radiosity block.
Need the surface to have a pretty high brilliance. Typically 100 to 1000.
This blurring seems to be similar to phong highlights : Higher value =
more and sharper reflection.
Date: 29 May 2026 12:18:37
Message: <6a19bc5d@news.povray.org>
>> 3.7?
> in POV-ray?"
Thanks, Kenneth, for reminding us of this tip. I’d never tried it
before, but you can get good results quickly with this method.
#declare BlurAmount = 0.15;
#declare BlurSamples = 40;
normal {
   wrinkles BlurAmount
   translate <rand(S),rand(S),rand(S)>/2
   scale 0.001
kurtz le pirate
compagnie de la banquise
Download 'blurred.jpeg.jpg' (144 KB)
Preview of image 'blurred.jpeg.jpg'
Date: 30 May 2026 13:00:00
Message: <web.6a1b166abb25f7d0228b8f50d49cbb40@news.povray.org>
> >> 3.7?
> > in POV-ray?"
> normal {
>    wrinkles BlurAmount
>    scale 0.001
> kurtz le pirate
It's a shame that I have a crappy phone, and my PC has passed on to a better
world.;]
Date: 30 May 2026 23:50:00
Message: <web.6a1baf59bb25f7d0bd297318949c357d@news.povray.org>
> 3.7?
This file contains macros that implement the solution that Kenneth referred to:
  https://github.com/CousinRicky/POV-RC3Metal/blob/main/rc3metal.inc
RC3Metal_Blur_t() is a naive implementation.  It's perfectly fine for a simple
object with no other reflective object in the scene, but it can bring your CPU
to its knees if there are mutual blurred reflections.
RC3Metal_Blur() uses the optimization that Alain described.
The argument t_Base is the reflective texture that you want to blur.
Note that if t_Base has a normal, the above macros will not work as expected.
Use macros RC3Metal_Normal_blur_t() or RC3Metal_Normal_blur() if you want a
blurred normal.
The entire library, including documentation and examples, can be downloaded at:
Date: 31 May 2026 06:45:00
Message: <web.6a1c1057bb25f7d01f9984c5d49cbb40@news.povray.org>
> >> 3.7?
> > in POV-ray?"
> normal {
>    wrinkles BlurAmount
>    scale 0.001
> kurtz le pirate
I managed to learn this result with 3 samples
Download 'ls9.png' (588 KB)
Preview of image 'ls9.png'
Date: 1 Jun 2026 08:42:35
Message: <6a1d7e3b$1@news.povray.org>
>> 3.7?
How to avoid this problem :
1) Give the objects with the blurred reflection the no_reflection attribute.
2) Create a second version of the objects with just normal reflection,
or the micro-normals based blurred reflection, and the no_image attribute.
> blurred normal.
