POV-Ray : Newsgroups : povray.binaries.images : Light bleeding: adding halos to the spikes Server Time
19 May 2026 21:59:30 EDT (-0400)
  Light bleeding: adding halos to the spikes (Message 1 to 4 of 4)
Subject: Light bleeding: adding halos to the spikes
Date: 19 Apr 2026 16:09:52
Message: <69e53690$1@news.povray.org>
I have been working on my light bleeding code, adding a circular halo to
the diffraction spikes.  But while the added glow (Spikiness 0.25) looks
a lot better, it is dreadfully slow, taking 31 minutes for a 512 x 256
render, versus 1.5 minutes for the spikes alone (Spikiness 1.00).  The
issue is that halos scale with the square of the radius, while spikes
scale linearly.
Looks like I'll be investigating Sam's technique to see if I can work
out a hybrid that won't take forever.  Sam's lb7b allows me to add my
own diffraction pattern, while my idea has been to bleed only color
channels in excess of 1.0.
Or, I could attempt to upgrade Nathan Kopp or Chris Colefax to POV-Ray
3.7/3.8, but I would rather not have to track light sources--especially
since this does not account for reflections and highlights.
I'm just noticing another lens flare library on my computer, credited to
Zeger Knaepen in my notes, though his name is not in the code anywhere.
Download 'bleed_poc5-glow29.jpg' (55 KB) Download 'bleed_poc5-glow33.jpg' (57 KB)
Preview of image 'bleed_poc5-glow29.jpg'
Preview of image 'bleed_poc5-glow33.jpg'
Subject: Re: Light bleeding: adding halos to the spikes
Date: 20 Apr 2026 06:21:20
Message: <69e5fe20$1@news.povray.org>
In fact, there are several examples on Zeger Knaepen's website... but no
code found. <https://povplace.com/index.php?t=3>
In any case, great work on these halos and spikes.
kurtz le pirate
compagnie de la banquise
Date: 20 Apr 2026 06:50:00
Message: <web.69e603b14af273a416086ed06830a892@news.povray.org>
> scale linearly.
Yes, great work indeed, the pursue is worth it: looking much more realistic with
halo.
Date: 20 Apr 2026 06:55:00
Message: <web.69e605614af273a416086ed06830a892@news.povray.org>
Did you think about abusing the rainbow primitive for this effect?
(I assume you did find this discussion with the same attempt in your search :
https://news.povray.org/povray.general/thread/%3C3BE87585.572DA5DB%40scifi-fantasy.com%3E/?ttop=445854&toff=6650)
