POV-Ray : Newsgroups : povray.macintosh : building povray on mac Server Time
17 Jan 2026 00:43:14 EST (-0500)
  building povray on mac (Message 1 to 4 of 4)
Subject: building povray on mac
Date: 2 Jan 2026 10:59:05
Message: <6957eb49$1@news.povray.org>
Best wishes for this new year, which is off to a funny start for me.
After my tests on Ubuntu, I decided to compile POVRay on MacOS Sequoia
(15.7.3).
I get sources here : https://github.com/POV-Ray/povray
I installed the libraries with brew.
Some information about the result:
 > povray -version
POV-Ray 3.8.0-alpha.unofficial
This is an unofficial version compiled by:
  kurtz le pirate <kur### [at] freefr>
  The POV-Ray Team is not responsible for supporting this version.
Copyright 1991-2019 Persistence of Vision Raytracer Pty. Ltd.
This is free software; see the source for copying conditions.  There is
NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Built-in features:
   I/O restrictions:          disabled
   X Window display:          disabled
   Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff
   Unsupported image formats: openexr
Compilation settings:
   Build architecture:  x86_64-apple-darwin24.6.0
   Built/Optimized for: x86_64-apple-darwin24.6.0 (using -march=native)
   Compiler vendor:     gnu
   Compiler version:    g++ 17.0.0
   Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
                        -Wsuggest-override -O3 -ffast-math
                        -march=native -pthread
Not everything is perfect, but POV-Ray seems to be working except
that... when I try to render I get a "empty" image with only the
background color and the output file has been successfully created.
Tested with several standard 3.8 scenes and multiple file formats with
this command line:
	povray fractal1.pov +W800 +H600 +FN8
No error on output console.
Others info about lib with povray -? command:
Support libraries used by POV-Ray:
   ZLib 1.2.12, Copyright 1995-2012 Jean-loup Gailly and Mark Adler
   LibPNG 1.6.53, Copyright 1998-2012 Glenn Randers-Pehrson
   LibJPEG 8, Copyright 1991-2016 Thomas G. Lane, Guido Vollbeding
   LibTIFF 4.7.1, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
   Boost 1.90, http://www.boost.org/
Does anyone have any idea what might be happening and
can give me a clue as to how to resolve this issue?
kurtz le pirate
compagnie de la banquise
Subject: Re: building povray on mac
Date: 3 Jan 2026 11:09:04
Message: <69593f20$1@news.povray.org>
The blank render is one of a few bad results of newer g++ versions
changing the fast-math flag behavior. While running the configure script
add the additional flag mentioned below:
"Those using g++ compiler version 13 or later must add the compiler flag
-fno-finite-math-only, if using the flag -ffast-math."
Bill P.
Date: 3 Jan 2026 12:15:47
Message: <69594ec3$1@news.povray.org>
* Firstly: Thank you for your reply.
* Secondly: So this problem is known. I feel better.
* Finally: I tried adding the -fno-finite-math-only option in several
files (where CXXFLAGS=... ), but it is not taken into account. In the
end, I still have:
povray --V
no /-fno-finite-math-only/
In which file(s) should this option be added?
./configure does not seem to accept this option,
or I did not know how to do it :(
kurtz le pirate
Date: 3 Jan 2026 15:23:04
Message: <69597aa8$1@news.povray.org>
Something like:
./configure COMPILED_BY="wfp" CXXFLAGS="-fno-finite-math-only"
should work to add the compiler flag for official POV-Ray source releases.
Bill P.
