POV-Ray : Newsgroups : povray.advanced-users : Getting the most from CPU Server Time
4 Dec 2025 20:46:24 EST (-0500)
  Getting the most from CPU (Message 1 to 3 of 3)
Subject: Getting the most from CPU
Date: 9 Nov 2025 06:43:18
Message: <69107e56$1@news.povray.org>
Now, after successfully build of 3.8.0-beta2 for my home dated
Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz, I would like to ask you how to
make a build for powerful architecture which supports more advanced
instructions set.
If I understand well, CPU optimization is switched on by default. The
question is: how to get the most from a particular CPU - are there any
options or defines to turn on support of particular architecture
features ?
Now I see in the following, when asking 'povray --help':
Dynamic optimizations:
CPU detected: AMD,FMA4
Noise generator: generic (portable)
YB
Subject: Re: Getting the most from CPU
Date: 9 Nov 2025 07:50:00
Message: <web.69108d631a1716b0475fba6a6cde94f1@news.povray.org>
hi,
> Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz, ...
strange.  on my "elderly" i5, the help option reports CPU Intel (with
SSE2,AVX,AVX2,FMA3) and noise generator 'avx2fma3-intel'.
fwiw, when the correct CPU is detected, find out which "chipset" ('Haswell' for
this machine), and check if the compiler "knows" that, ie I can use the
'-march=haswell -mtune=haswell' GCC options.  unsure about "performance boost"
regards, jr.
Date: 9 Nov 2025 09:44:39
Message: <6910a8d7$1@news.povray.org>
Nothing strange - at home I have Intel, but now building version for
hosting provider's server that works under "AMD EPYC 7763 64-Core" and
want to make optimal configuration.
I will be happy if you suggest me the best options for this
hardware.
YB
