POV-Ray : Newsgroups : povray.binaries.images : Ring Server Time
16 Apr 2026 04:04:50 EDT (-0400)
  Ring (Message 1 to 8 of 8)
Subject: Ring
Date: 15 Oct 2025 23:15:44
Message: <68f06360@news.povray.org>
This is the result of conversion and rendering in a studio environment
with materials from Mike Miller. I will post the scene in
'povray.text.scene-files' - any suggestions about quality improvement
of similar models (jewelry) are highly appreciated.
YB
Download 'ring.png' (243 KB)
Preview of image 'ring.png'
Subject: Re: Ring
Date: 16 Oct 2025 06:43:52
Message: <68f0cc68@news.povray.org>
> YB
It looks like your material have a rather high ambient value. That make
that gold look as if it was plastic. Try setting ambient 0.
Subject: Re: Ring
Date: 16 Oct 2025 09:02:34
Message: <68f0ecea$1@news.povray.org>
Thanks for suggestion, but it's already == 0:
#declare F_metal  =
finish {
     reflection {0, 1 fresnel on }
     conserve_energy
     brilliance 5
     ambient 0
     diffuse .5
     phong 5
     phong_size 40
     metallic
     specular .4
     roughness 1/20
     reflection .5
YB
Subject: Re: Ring
Date: 17 Oct 2025 15:35:36
Message: <68f29a88$1@news.povray.org>
>> make that gold look as if it was plastic. Try setting ambient 0.
> #declare F_metal  =
> finish {
>      conserve_energy
>      brilliance 5
>      ambient 0
>      diffuse .5
>      phong 5
>      phong_size 40
>      metallic
>      specular .4
>      roughness 1/20
>      reflection .5
> YB
Your diffuse seems to high for a metal. Normally, I use something less
than 0.1.
Fresnel reflection for a metal ? Fresnel is for objects that have an IOR
and are not metals. Useful when you want to simulate a varnish coat on a
metallic object using a layered texture. In that case, don't forget to add
interior{ior 1.6}// or something similar.
One base texture with the metallic texture, then, another transparent
texture with the fresnel reflection, followed by an interior block
giving the IOR of the varnish.
My suggestion :
#declare F_metal  =
finish {
     brilliance 5
     ambient 0
     diffuse .05 // Lower diffuse
     metallic
     specular .4
     roughness 1/20
     reflection {.5 metallic}
#declare Varnish =
material{
	texture{
		pigment{rgbt 1}
		finish{
			reflection{1 fresnel}
			phong 1
			phong_size 40
			fresnel
	interior{ior 1.55 dispersion 1.02}
Then, maybe it's the environment that is to bright... The appearance of
metals depend a lot on the environment.
Subject: Re: Ring
Date: 17 Oct 2025 16:25:01
Message: <web.68f2a521c125c60b8f1ef7f525979125@news.povray.org>
> and are not metals.
I recall reading that accurately rendering metals required an IOR.
Maybe not for current POV-Ray though.
https://www.behance.net/gallery/35636521/Material-Studies-Metals
etc.
- BW
Subject: Re: Ring
Date: 17 Oct 2025 17:02:08
Message: <68f2aed0@news.povray.org>
> than 0.1. ...
Thanks, Alain, now it's much better, but looks more like brass,
then gold. I will try to play with pigment now.
YB
Download 'ring.png' (134 KB)
Subject: Re: Ring
Date: 18 Oct 2025 09:38:56
Message: <68f39870$1@news.povray.org>
>> and are not metals.
> etc.
> - BW
And the IOR of metals tend to be complex numbers.
Subject: Re: Ring
Date: 11 Nov 2025 11:50:00
Message: <web.691368cdc125c60bb46f90e66a8f0b95@news.povray.org>
> than 0.1.
> My suggestion :
> #declare F_metal  =
> finish {
>      brilliance 5
>      ambient 0
>      metallic
>      specular .4
>      roughness 1/20
> #declare Varnish =
> material{
>  texture{
>   pigment{rgbt 1}
>   finish{
>    phong 1
>    phong_size 40
>    fresnel
I am now wondering how many metal textures I have created that didn't follow
this advice ;-)
