![](/i/fill.gif) |
Please see the attached tarballs, previous announcements in this forum
and INSTALL.txt for suggestions on compiling and running via wrapper script.
Note. The yuqk_DocAndAid_2f941611.tar.gz and
yuqk_Examples_2f941611.tar.gz files will be attached to a response to
this posting.
A reminder the yuqk fork is not POV-Ray. As time passes, it's less
likely existing POV-Ray scenes will work without modification.
Bill P.
Added the following vm inbuilt functions: f_2x_f32_vadd, f_2x_f32_vaddc,
f_2x_f32_vdiv, f_2x_f32_vdivc, f_2x_f32_vdot, f_2x_f32_vinv,
f_2x_f32_vlength, f_2x_f32_vlength_sqr, f_2x_f32_vmul, f_2x_f32_vmulc,
f_2x_f32_vnormalize, f_2x_f32_vsub, f_2x_f32_vsubc, f_3x_f21_vadd,
f_3x_f21_vaddc, f_3x_f21_vcross, f_3x_f21_vdiv, f_3x_f21_vdivc,
f_3x_f21_vdot, f_3x_f21_vinv, f_3x_f21_vlength, f_3x_f21_vlength_sqr,
f_3x_f21_vmul, f_3x_f21_vmulc, f_3x_f21_vnormalize, f_3x_f21_vsub and
f_3x_f21_vsubc.
Removed a back door feature allowing library paths to be specified
without flag or option settings so long as the 'floating' path ended in
a path separator ('/' on unix/linux). For example:
povray /tmp/RTR/ test.pov
would add '/tmp/RTR/' to the library paths including the trailing '/'
triggering the back door. The feature existed despite the trailing '/',
by some code and our documentation, being illegal..?
The ini file extension defaulting is now restricted as compared to
official POV-Ray releases. Unknown strings on the command line or in ini
files will no longer default to attempts to read an ini file with a
suffix variations of the string. The feature exposed users to confusing
results. Floating ini files on the command line or within ini files must
now be specified with the '.ini' extension. For example, use:
yuqk +l$HOME/myinifiles scene.ini
over:
Any ini files specified with the +-ini flag / include_ini= option may
still be specified without the '.ini' extension.
Fix for issue where only the first specified library path was searched
for ini files not in the current directory - or fully specified with
+-ini or include_ini.
Fix where errors inside ini files specified with +-ini<filename> or
include_ini=<filename> were being ignored (error state was overwritten).
Fixes for a number of obscure issues while parsing .pov and .ini file
specifications.
The rainbow{} feature removed. This includes the removal of following
keywords specifically dedicated to it: 'arc_angle', 'falloff_angle' and
'width'. The rainbow feature related uses of the following keywords have
also been removed: 'angle', 'direction', 'distance', 'jitter' and 'up'.
Download 'povray-3.8.0-x.yuqk_2f941611.tar.gz' (1676 KB)
![](/i/fill.gif) |
