POV-Ray : Newsgroups : povray.beta-test : Re-discovering issues with finding ini files in library path Server Time
27 Jul 2024 07:59:31 EDT (-0400)
  Re-discovering issues with finding ini files in library path (Message 1 to 3 of 3)
Subject: Re-discovering issues with finding ini files in library path
Date: 20 Mar 2024 01:49:06
Message: <65fa78d2$1@news.povray.org>
Aside: New thread as original not recovered after the crash with respect
to the news server itself, which leaves Thunderbird unable to continue it.
Ref:
https://news.povray.org/povray.beta-test/message/%3C5bdf75ab%241%40news.povray.org%3E
[insert long back story here] ... My thinking was the ini include
searching of the library path was working fairly well despite what some
had said.
I recently re-enabled the parsing of a users local povray.ini and
povray.conf files stored in $HOME/.povray/3.8
Turns out. If the ini file you want isn't in your local directory - and
the library path where it exists isn't the first listed in the reported
library paths parsing cannot find it and dies.  :-(
The only immediately useful thing for those with $HOME/.povray
povray.ini files, you can use the shipped ini files if you change:
     Library_Path="__POVLIBDIR__"
     Library_Path="__POVLIBDIR__/ini"
     Library_Path="__POVLIBDIR__/include"
to
With that change I'm able to run the following (reminder yuqk is
linux/unix only):
     yuqk playpen.pov include_ini="quickres.ini[1024x768, AA 0.3]"
or
     yuqkZ playpen.pov +ini"quickres.ini[1024x768, AA 0.3]"
Of course, with that set up you can then only reach local directory ini
files afterward because those are all that will be found.
I was getting fooled as to the state of things. I mostly run without
$HOME./povray local povray.ini and povray.conf file. So, when I added
the ini included directory to the library path files, things worked -
because that path happened to be the first in the list of library
directories.
Bill P.
Aside(2): The yuqk fork itself does not ship the ini directory of files
at present. They existing ones are very much out of date.
Subject: Re: Re-discovering issues with finding ini files in library path
Date: 15 Apr 2024 22:49:13
Message: <661de729$1@news.povray.org>
> linux/unix only):
> or
First, as an addition to the previous post, I should have added as a
footnote that using include_ini= (*) or +ini with a full path or
complete relative path specification for ini files works.
Today. These options are in fact the only way other than copying all the
ini files you need into the local rendering directory to be sure(**) you
find ini files (other than install or user-local povray.ini) correctly.
(*) - The include_ini= option exists today in official releases, but
isn't documented.
(**) - This isn't the same as saying the current ini mechanism doesn't
often work. Of course, this is an ugly position to be in as it means the
ini behavior, where other than having all same directory ini file(s), is
unreliable.
The above said, the aim of this post is to document that I've found
issues with ini parsing error reporting when ini files are directly
included! :-(
(Yes, now guessing that, not documenting 'include_ini=' might have been
some sort of a 'delay for fixes' which never happened.)
Basically, ini files included via this mechanism can have serious
parsing issues which end up completely ignored in official releases of
POV-Ray (Linux / Unix versions at least). They are 'somewhat ignored'
with current releases of the yuqk fork.
The yuqk fork reports the parsing problems with additional text messages
where official releases usually don't. However, today in released yuqk
versions up to R13, the parsing still doesn't stop on finding serious
issues. The bad error return code gets eaten / overwritten due how the
include_ini= option was originally implemented.
Because it's part of the 'ini' tofix pile and related, I'll toss out
again that the ini directory ordering, as affected by library paths, is
glitch-y. We should not be using the library search paths for ini files
at all, but rather only for include files.
It believe it should always have been another path set up mechanism for
ini files (perhaps an INIPATH env var similar to PATH?). Or, no path
searching at all and just include_ini= or +ini usage. This latter
approach is how I plan to go with yuqk - though I've not yet worked out
the code changes to disable to sometimes searching of the library path
for ini files, so we'll see.
Bill P.
Date: 2 May 2024 04:57:05
Message: <66335561$1@news.povray.org>
> included!
I believe these issues now fixed in the upcoming release R14 of yuqk.
And with the library paths in v3.8+ onward(*); the problem with the ini
search mechanism only picking up the first search directory in the set
has been fixed for release R14 of yuqk.
While there are other fixes / changes in yuqk besides, I 'think' much
can be had in official v3.8+ POV-Ray releases by simply adding the line:
   libpath.clear();
just ahead of:
   if (POVMSAttr_GetUTF8String(&item,kPOVMSType_UCS2String,libpath) != 0)
in:
   ITextStream *ProcessRenderOptions::OpenINIFileStream(...)
in the file:  source/frontend/processrenderoptions.cpp
Things go wrong in POVMSAttr_GetUTF8String() and the collection of
functionality it calls in that the individual paths returned after the
first are mangled / blended with prior results.
I've kept the now working library path searching in yuqk rather than
create an alternate approach / method for it - though I think any
eventual v4.0 offering should set up a separate 'ini path'.
(*) - The v3.8+ code is different than the v3.7 code. Unsure how v3.7
works with respect to ini files and searching the specified library path.
Bill P.
