POV-Ray : Newsgroups : povray.general : Need help with texture_map Server Time
20 Apr 2024 06:49:33 EDT (-0400)
  Need help with texture_map (Message 1 to 7 of 7)
Subject: Need help with texture_map
Date: 20 Mar 2023 22:42:38
Message: <6419199e$1@news.povray.org>
I solved this problem a couple of years ago with my "Portland Burns"
image. The hard drive with all my code died and I can't seem to recreate it.
The idea is to create a texture map that allows for a transition between
two other textures with a transition zone in-between. A quick sketch:
box {
   <0, 0, 0>, <1, 1, 0>
       planar
       texture_map {
         [clock-0.01 Final_Texture ]
         [clock-0.01 Transition_Texture ]
         [clock Transition_Texture ]
         [clock Clear_Texture ]
But if I scale this texture or add turbulence on the outer texture, the
inner textures are also scaled or transformed.
I swear I had pulled this off before but I can't suss it this time.
Any suggestions?
Josh English
Subject: Re: Need help with texture_map
Date: 21 Mar 2023 08:38:05
Message: <6419a52d$1@news.povray.org>
Op 21-3-2023 om 03:42 schreef Josh English:
> it.
> box {
>    texture {
>        planar
>        texture_map {
> Any suggestions?
> Josh English
Interesting question.
What about warp{} ? I didn't test this but what if you do a first
transformation within a warp statement /before/ the texture_map {} and a
second warp statement /after/ the texture_map{}, reversing somehow your
earlier warp transformation. Somehow, it seems not to make any sense at
all but who knows...
Something else I was thinking was to make those reverse transformations
(within a warp or not by the way) to the inside textures individually,
and then apply the correct transformations to the outside texture? No
idea if that would do what you want...
Date: 21 Mar 2023 10:15:00
Message: <web.6419bb949474913ba2e6a155cc1b6e@news.povray.org>
> box {
>    texture {
>        planar
>        texture_map {
> Any suggestions?
> Josh English
I generally solve this problem by using a pigment_pattern{} in the outer texture
 rather than the pattern directly.
    pigment_pattern {
        planar
        // apply transformations here
    texture_map {
       [clock-0.01 ...]
That way your transformations apply to the planar mapping without distorting the
textures inside of the texture_map.  I believe you can also apply the
transformations within the body of the outer texture and it will still only
apply to the pigment_pattern without altering your inner textures.
-- Chris R.
Date: 21 Mar 2023 23:27:30
Message: <641a75a2$1@news.povray.org>
>> box {
>>     texture {
>>         planar
>>         texture_map {
>> Any suggestions?
>> Josh English
> texture {
>      pigment_pattern {
>          planar
>      texture_map {
>         [clock-0.01 ...]
> -- Chris R.
I think that's it. It works just like I remembered my Portland Flag
image. For some reason using pigment_pattern in a top level of the
texture definition seems, well, wrong.
Thank you.
-- Josh
Date: 21 Mar 2023 23:28:21
Message: <641a75d5$1@news.povray.org>
>> recreate it.
>> between two other textures with a transition zone in-between. A quick
>> sketch:
>> box {
>>    texture {
>>        planar
>>        texture_map {
>> the inner textures are also scaled or transformed.
>> Any suggestions?
>> Josh English
I had tried those and they simply didn't work. Chris R has the trick I
had forgotten.
Thanks, though.
Now I can try to move on to the next part of the over-designed project : )
-- Josh
Date: 22 Mar 2023 03:16:41
Message: <641aab59$1@news.povray.org>
Op 21/03/2023 om 15:13 schreef Chris R:
Of course! :-)
I seem often to just forget about pigment_pattern{}.
[note to self: have to see shrink... or tattoo shop...  toss coin]
Date: 22 Mar 2023 11:45:00
Message: <web.641b22099474913b879be96c5cc1b6e@news.povray.org>
> >> box {
> >>     texture {
> >>         planar
> >>         texture_map {
> >> Any suggestions?
> >> Josh English
> > texture {
> >      pigment_pattern {
> >          planar
> >      texture_map {
> >         [clock-0.01 ...]
> > -- Chris R.
> Thank you.
> -- Josh
Think about pigment_pattern as a pattern that uses a pigment to define the
boundaries for the *_map you want to use, rather than a pattern that applies to
pigments and it won't seem so wrong...
-- Chris R.
