POV-Ray : Newsgroups : povray.bugreports : uv_mapping bug on cylinders Server Time
19 Apr 2024 20:30:47 EDT (-0400)
  uv_mapping bug on cylinders (Message 1 to 10 of 10)
Subject: uv_mapping bug on cylinders
Date: 3 Aug 2022 10:40:00
Message: <web.62ea88024cd911261ec2018a5cc1b6e@news.povray.org>
I encountered an issue with v3.8 beta 2 using uv_mapping textures on cylinders
while creating a label for a bottle.  I did search through the newsgroups for
any other report of this and didn't find anything that matches my problem.
The original texture is fairly complex and involves using an object pattern with
a text object as the "object" and fully-specified textures for the ink and the
background of the label as the texture list.  However, I was able to simplify it
considerably to the following:
            cylinder {
                <0, 0, 0>,
                <0, 20, 0>,
                5
                texture { uv_mapping pigment { brick color rgb 0 color rgb 1 } }
            cylinder {
                <0, 0, 0>,
                <0, 20, 0>,
                5
                translate <20, 0, 0>
As you can see, the second cylinder is translated after applying the texture,
but if you look at the brick pattern, it appears the uv_mapping is being applied
to the translated object first, because the bricks do not line up.
In my bottle example, the text doesn't show up at all in the translated bottle,
because the entire bottle is outside of the text object's boundaries after it is
translated.
-- Chris R.
Download 'magic.png' (91 KB)
Preview of image 'magic.png'
Subject: Re: uv_mapping bug on cylinders
Date: 3 Aug 2022 10:45:00
Message: <web.62ea89b1f9bd2f341ec2018a5cc1b6e@news.povray.org>
>             cylinder {
>                 <0, 0, 0>,
>                 <0, 20, 0>,
>                 5
>             cylinder {
>                 <0, 0, 0>,
>                 <0, 20, 0>,
>                 5
> translated.
> -- Chris R.
Just as additional information, adding a "translate <20, 0, 0>" after the
pigment declaration in the second texture corrects the problem.
-- Chris R.
Date: 3 Aug 2022 18:21:00
Message: <62eaf4cc$1@news.povray.org>
>>              cylinder {
>>                  <0, 0, 0>,
>>                  <0, 20, 0>,
>>                  5
>>              cylinder {
>>                  <0, 0, 0>,
>>                  <0, 20, 0>,
>>                  5
>> translated.
>> -- Chris R.
> -- Chris R.
IIRC the uv_mapping feature for cylinders and cones(a) is currently
disabled in recent v3.8 / v4.0 code. I believe you are getting some sort
of default planar mapping(b).
(a) - And other shape(s) where mapping didn't exist in v3.7.
(b) - Unsure what corrections for transforms and mapping spaces might be
getting done or not with it. You could roughly test for planar mapping
by moving the right cylinder in x by 5+1e-6, say.
More if interested. As remembered by my old flaky memory...
Cylinders and some other shapes did not previously support uv_mapping in
v3.6/v3.7 though the keyword was allowed by the parser with no warning
it's not really working. Jerome added code to do the mapping for
cylinders, cones and other shape(s).
Christoph, later found a longstanding issue related to unstable mapping
orientation - and he disabled all the new to v3.8/v4.0 uv_mapping
updates. The problem noted exists for older mappings too, like the ovus,
but it had uv mapping in v3.7 and Christoph decided to leave it as is
for v3.8.
Last I knew, the documentation reflects the uv mapping as it was with
the new uv_mapping shapes and not the current code state.
Jerome proposed fix for Christoph's concern, which I think is in
hgpovray38, but I've not looked at it in detail. It wasn't
adopted/merged in the official code.
Aside: I 'sort of' understand Christoph's concerns and Jerome's
proposal, but I have additional questions relating to shapes like
spheres which the parser 'sometimes' flattens to an already transformed
position/orientation. I'd guess any better uv_mapping specification/code
would have to track/work with the parser to maintain any specified
uv_mapping orientation there too.
Aside 2: There are two additional ways to do cylindrical mapping of
textures via warps and image_maps.
Bill P.
Date: 3 Aug 2022 19:40:00
Message: <web.62eb0633f9bd2f341f9dae3025979125@news.povray.org>
Supplemental Aside #3:
You can also uv-map an object by writing your own function to texture the
object's surface.   If you're into that sort of thing.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5d5757a84c72a7284eec112d0%40news.povray.org%3E/?ttop=430135
&toff=50
Date: 4 Aug 2022 02:40:01
Message: <62eb69c1@news.povray.org>
Op 04/08/2022 om 01:35 schreef Bald Eagle:
> &toff=50
...which reminds me to ask you (curiosity): how does
#declare U = function (X, Y, Z) {(0.5 + atan2 (N(Z, X,Y,Z), N(X,
X,Y,Z))/(2*pi))}
#declare V = function (X, Y, Z) {(0.5 + asin(N(Y, X,Y,Z))/pi)}
work? is puzzling, as far as atan2 and asin are concerned.
Date: 4 Aug 2022 06:40:00
Message: <web.62eba114f9bd2f341f9dae3025979125@news.povray.org>
> X,Y,Z))/(2*pi))}
> Thomas
I don't have the file accessible to me ATM, but IIRC, the N() function is
probably just a select () for whichever vector component is specified as the
first argument. (*)
Then the atan2 returns an angle between -pi and pi, based on z and x.
Dividing by tau gives values between -0.5 and 0.5, and then everything is
shifted to between 0 and 1.
asin returns an angle between -pi/2 and pi/2.
Dividing by pi gives values between -0.5 and 0.5, and then everything is shifted
to between 0 and 1.
(*) And the way THAT works, is taking the specified vector components and doing
something like x*(-1) + y*0 + z*(2).  That should give you a -1, a 0, or a 2
depending on which cardinal vector is specified.
select () then returns one of three scalar values depending on what component it
spits out.
Date: 4 Aug 2022 08:41:19
Message: <62ebbe6f$1@news.povray.org>
Op 4-8-2022 om 12:36 schreef Bald Eagle:
>> X,Y,Z))/(2*pi))}
>> Thomas
> first argument. (*)
> to between 0 and 1.
> spits out.
OK thanks. Sorry for diverting from the original post subject. I'll shut
up now. :-)
Date: 4 Aug 2022 12:31:09
Message: <62ebf44d$1@news.povray.org>
>              cylinder {
>                  <0, 0, 0>,
>                  <0, 20, 0>,
>                  5
>              cylinder {
>                  <0, 0, 0>,
>                  <0, 20, 0>,
>                  5
Hello,
Any hope to get the full simplified scene of the picture ?
(it's for my experiment, you can send it directly if you do not want to
bother the newsgroups)
William clearly summarised the sequence of events.
Date: 4 Aug 2022 14:25:00
Message: <web.62ec0e1cf9bd2f341ec2018a5cc1b6e@news.povray.org>
> >              cylinder {
> >                  <0, 0, 0>,
> >                  <0, 20, 0>,
> >                  5
> >              cylinder {
> >                  <0, 0, 0>,
> >                  <0, 20, 0>,
> >                  5
> Hello,
I simplified it even further in the attached .pov file.
-- Chris R.
Download 'uv_mapping.pov.txt' (1 KB)
Date: 5 Aug 2022 12:55:07
Message: <62ed4b6b$1@news.povray.org>
> -- Chris R.
Thanks.
The script frightened me a bit for hgpovray38 until I remembered to
scale down the texture (by factor of 1/30 or so) to be able to see the
pattern. Moving the second cylinder is safe.
I also moved the light further away.
Download 'hg.png' (29 KB)
Preview of image 'hg.png'
